-   -   Where to get A/C system plugs (http://forums.pelicanparts.com/porsche-911-technical-forum/121927-where-get-c-system-plugs.html)
surflvr911sc 08-04-2003 12:16 PM
I need to remove my A/C compressor and engine lid condenser on my SC. I want to keep the system sound so I can reinstall the A/C at a latter so I need to properly plug the fittings.
Does anyone know what the best place to get the right plugs would be? I want to avoid removing everything and taking the parts to the hose shop and hope that they have the right ones after it’s already apart.
ruf-porsche 08-04-2003 08:14 PM
You can buy flare fitting caps at the Home Depot. That will cap the compressor. They are 1/2 and 5/8 inch size caps. For the hose you need to find male plug, same size as the caps. Or you can buy a double male flare fitting and just buy a cap to cap the hose.
surflvr911sc 08-04-2003 08:31 PM
Thanks, Do you happen to know the actual sizes?
ruf-porsche 08-04-2003 09:00 PM
Yes read my post. 1/2 and 5/8, the thread for flare fittings are the same
surflvr911sc 08-04-2003 10:25 PM
Doh! Thanks!
