oil line adapter
Hi,
Just received my oil line adapter H-107-348-XXX. First of all, congratulations on the handling. I ordered Wednesday evening and received Friday morning (in Belgium!) Very impressive. But why is there no "nut/ferrule compression fitting" on the inside fitting? There were on the oil lines that came with the tensioner upgrade kit. Please don't tell me I have to remove the fitting from the original oil line because I tried and it's impossible. At least not without destroying the thing. Thanks, Philip |
Philip,
The nuts and ferrules can be removed and reused ... but I usually put new ones on the cam tower lines when I install them.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
