sammygon1's Avatar
Cool Low rpm miss
Any ideas on what would cause a low rpm miss. After 4k rpms car runs and pulls fine but before that miss is present. Engine is a 2.4 in a 72T with CIS. CIS was added not sure from what year. Not my car just considering purchasing it. Thanks.
Old 08-07-2003, 11:48 AM
ruf-porsche's Avatar
Spark plug wires?
Old 08-07-2003, 12:38 PM
sammygon1's Avatar
Maybe the wires, but if they were bad wouldn't it be worse at high rpms.? I'm wondering if its a burned valve.
Sam Gonzales
'69 912 2.0 -6 power
Old 08-07-2003, 12:49 PM
A compression and leak down test will tell you if you have a burnt valve. One of the wire resistance may be a little off so you haved a weak spark in that cylinder, but as you race the engine the weak cylinder is cover up by the other cylinders.
Old 08-07-2003, 08:39 PM
