Disconnecting Oil Line to Oil Cooler
Gang:
I am trying to disconnect the lines that connect my hard lines to my front oil cooler.
I've soaked them with liquid wrench, heated them with a propane torch, and had friend (who is much stronger than I) try to loosen them.
I can't get them loose.
What/How Now?
I really want to get this disconnected so I can run lines to my new front oil cooler.
Brian
Brian Keith Smith
Old 08-04-2003, 06:22 PM
Jim Smolka's Avatar
If brute force does not work, then more brute force may be needed. I have heard of folks having to cut the nut before the oil lines will break loose, though this is typically back at the thermostat end input side.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-04-2003, 06:31 PM
USE KROIL THE OIL THAT KREEPS.
Old 08-07-2003, 09:01 AM
Chuck Moreland's Avatar
I don't recommend heat. You are baking oil residue onto the inside of the tubes, and damaging the flex hose rubber.
Use PB blaster, it's a much better penetrant than liquid wrench.
As Jim says, you can also cut the nuts off. The hoses aren't that expensive to replace.
Chuck Moreland - elephantracing.com - vonnen.com
Old 08-07-2003, 09:05 AM
IROC's Avatar
Kroil didn't work for me. I had to use the "wheel of death" as Dave Seeland calls it....the air powered cut-off wheel...to cut the nut....
Kroil is the best penetrating oil I have ever used, though.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 08-07-2003, 09:06 AM
RETIRED
Joe Bob's Avatar
Kind of trailer trash engineering....but I used a pair of vice grips....then put a pipe on each one. Obviously not on the arms that trigger the release....the other side....8^)
Then one person on one pipe, me on the other....snap. They cracked open.
2012 ML350 3.0 Turbo Diesel
Old 08-07-2003, 09:16 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
I used a similar method to Mike but the other person was my foot. Not easy to break them apart and I ended up having new oil lines manufactured.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-07-2003, 09:21 AM
Gang:
I got them off. I spent $85 and bought 2 huge S&K wrenches (they must weigh 8lbs each). Brought them home and popped the first one off in like 2 minutes. The other one took a while longer, but in less than 15 minutes I had them both off.
I guess it truly pays to have the right tools...
Brian
Brian Keith Smith
Old 08-07-2003, 09:43 AM
In case you didn't see the other thread I started, here is what I did once I got them broken loose...
934 front end pics with new oil cooler
Brian Keith Smith
Old 08-07-2003, 09:44 AM
RETIRED
Joe Bob's Avatar
If you use them once more in your lifetime, they are paid for.....
Heck, I’m only 5 not 71!
targa80's Avatar
I used to large Crescent wrenches with pipes added on the end for leverage.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 08-07-2003, 09:47 AM
I cut mine with a dremel, just enough to put a screwdriver in the cut and twist to split the nut. Do not want to cut the threads on the inside.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 08-07-2003, 02:08 PM
