Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
NEED HELP! Replacing rear deck panel
Hi all,
I'm just about to embark on replacing my rusty rear deck with a patch panel I've thieved from another 911. If anyone has done this, I'd love to have some insight/tips/tricks to make it a less daunting task. I expect that it will be 20-30 hours of work, and will require lots o' welding. You can see what I'm replacing here:
http://www.whirledmedia.com/rustpanel/rustpanel.html
(You can click on the pics for detail views.)
Pics, advice appreciated!
Thanks in advance!
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 08-12-2003, 10:27 AM
Depends on whether or not you're going to cut and weld or drill then weld...ie, do you want to spend hours drilling out the spot welds (some you'll end up cutting as they're a string of spots that form a line) or just cut and patch...
For the drilling:
buy several spot weld bits
clean off all of the undercoating to see where the spot welds are (they're more than you think!)
Do the process in several steps so you don't get frustrated....
I did half the spot welds one night, the next night I did the other half...then I spent 1 night drilling out the spots on the donor piece...then another night welding in the new piece.
Per
Old 08-12-2003, 12:19 PM
Rennch on YouTube
rennch's Avatar
Per...any pics?
Thanks,
mto
Michael O'Neal -
Old 08-12-2003, 12:47 PM
Crusty Conservative
silverc4s's Avatar
Get a new gasket for the engine tin to body sealing area while you have it all apart.. yours is pretty much shot...;-)
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 08-12-2003, 01:11 PM
just the ones at www.classicmotorsports.net/911.html
Old 08-12-2003, 01:13 PM
