Autodidactic user
David E. Clark's Avatar
Question Quick valve noise question
Does the valve gap get wider or tighter as the engine warms up? In more practicle terms, should my 1973 2.4 valves be quieter at 230 degrees than they are at 180 degrees? I just finished a valve adjustment and the valves seem noticably noiser at 180 degrees than at 230 degrees. Is this normal? I didn't notice this prior to the valve adjustment (I wasn't listening for it however). Thanks
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 08-11-2003, 09:22 AM
Friend of Warren
Tighter. Metal expands with heat. Some valve noise will always be present. If not I would be worried the valves are adjusted too tight.
Kurt V
Old 08-11-2003, 09:25 AM
VenezianBlau 87's Avatar
I am following these valve clearance threads with interest. I have noticed my motor's clicking is more pronounced with motor up to normal temp than when I first start up. I would expect things to quiet down after heating up. Is'nt the point of the clearance to allow for heat expansion and to ensure valves close all the way.
I rushed last weekend and set mine too loose and will redo this weekend properly. It's just odd that it's only noticeable when motor hot.
If it's my valve guides, why is'nt oil blowing past like a DDT fogger?
Sorry no answers here; just wondering...
Bob
Bob S.
'87 911 ("Hardtop" per neighbor)
Old 08-11-2003, 09:51 AM
