Left cam tower oil fitting update
Hi,
I recently changed the right cam tower oil fitting and wanted to change the left one tonight. Can you install the left oil fitting without removing the cam oil line? Is it possible to move the line a little to remove the fitting?
I understand that in order to remove the line, I would have to remove the distributor which I would like to avoid.
Neil
'73 911S targa
Old 08-12-2003, 08:19 PM
ruf-porsche's Avatar
I replace the left cam oil line a couple of week back, but I removed the dizzy. I think that it would be almost impossible to remove the oil line without removing the dizzy out of the way.
Old 08-12-2003, 08:28 PM
Ruf-Porsche,
Thanks for the answer. My explanation should have been a little clearer. I want to replace the oil fittings as pictured below
If I can't do it without removing the distributor, I guess I will wait and do the upgrade next time I really need to mess with the timing.
Neil
'73 911S targa
Old 08-12-2003, 08:58 PM
Early_S_Man's Avatar
Porsche Crest
Neil,
The oil line doesn't have to be removed ... it can stay in place while the banjo bolt is removed and the three sealing rings and adapter are replaced.
The end of the oil line underneath the distributor need not be disturbed.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-12-2003, 09:46 PM
