-   -   need help on 2.7 ignition (http://forums.pelicanparts.com/porsche-911-technical-forum/123282-need-help-2-7-ignition.html)
TimKern 08-13-2003 03:45 PM
I shorted out my "coil" on 2.7 RS, and now the CDI box won't whine, either.
[Installation is on original 914-6 with 2.7RS and Bosch (nor Marelli) distributor]
Installing new "coil," and looking for advice on voltage to CDI box. When I measure red wire to CDI (on 3-prong plug) I get very low (under 1 volt) reading.
If this isn't right, where should I look next?
Notes: When I crank engine, points do open and close; 12 volts.
Whether I crank or not, wire to "+" side of coil reads <1 volt (constant)
I've never had an ignition problem in the nearly 30 years I've owned this car...
Thanks! Tim
