distributor recurve?
Do I need to recurve my distributor when going from a 2.4 T engine to a 9.5:1 E camed 2.4? I looked at the specifications and both are exactly the same both at idle and at 6000 rpms. My question is even if they both start and end at the same place are the curves themselves different?
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
GAFB
Several BMWs |
Sounds like you have your motor situation in hand Tim.
Rich Mason 87 951 for sale $5500 Last edited by RichMason; 08-15-2003 at 06:18 AM.. |
GAFB
Edit: Shhhhh...be vewy qwiet...I am hunting wabbits...
Several BMWs Last edited by dtw; 08-15-2003 at 06:22 AM.. |
Does anyone with the shop manuals for the 2.4's have the distributor curve data? I only have data on the 2.0's and 2.2's. Is your distributor from an MFI'd or CIS's engine?
- John
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
It's a 73T MFI engine
Bandwidth AbUser
Tim, do you have a place in mind to do distributor work? I'm just keeping my eyes open in case I need to attend to the distributor in Lu's 73E. No one I've talked to around here (NoVA) knows where to go for dizzy work.
Good luck on your engine rebuild. What HP is it expected to put out?
Jim R. |
I have no clue who would do a distributor recurve at this point, but I'm going to my machineshop tomarrow. I'll ask him and see.
Dtw and I did a rough calculation and we're thinking that the engine I'm building, a 9.5:1CR E camed 2.4L, should make just under 180 HP. not a half bad jump from 140. Originally dtw and I were supposed to have the same exact specs for our engines but it turns out he's got some nice little crane cams instead of E's. They are halfway between an E and an S in terms of profile. His engine we guess should make just under 190. I guess there's no such thing as a stock T rebuild
Bandwidth AbUser
You're gonna put our poor ol' 73E to shame.
Jim R. |
lol! not really.. you've got a totally pristine car and it's a sunroof coupe at that. Ohh and my suspesion is utter crap at this point anyway so you'll still show me up.
GAFB
Now me on the other hand, I'll mop up the floor with the lot of ya!
Several BMWs |
Bandwidth AbUser
ROFLOL! Good one, Dave.
![]() 190HP...no problemo.
Jim R. |
GAFB
With the 993, no, definitely no problemo....
Several BMWs |
Bandwidth AbUser
I don't know...
Jim R. |
Tim,
All 2.4 T's, E', & S's had the same curve ... the ONLY differences between them was which rev-limiter rotor was fitted from the factory! Likewise for the 2.7 CIS engines, which used a 'T' spec distributor thru the end of '77 production!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
GAFB
Warren,
Best news I've had all day. One less thing to worry about on this rebuild.
Several BMWs |
Excellent news Warren. Thanks a bunch.
