SC Dash & Tire questions
More advice sought.
Car 79sc. Any recommendations for a cracked/slightly warped dash, I don't want to replace the whole thing and was thinking about some type of cover. Any recommendations for tires (type & size) for 8x16 (rear) and 7x16 (front) Fuchs. The car has been lowered. Use will be mostly pleasure with some autox. Thanks in advance. |
I installed a Coverlay cover and I'm somewhat happy with it. It took about an hour of careful trimming and fitting, though.
Mine isn't cracked, but does have some warping. I have a fabric cover ($35) and it doens't but me at all...
The Coverlay can cut down on clearance between the dash and steering wheel. |
Re: SC Dash & Tire questions
A popular chioce of tire is the Bridgestone S03. I am looking at these for my next set. Have fun! |
Tires
I had Dunlop SP8000s, now have Bridgestone SO-3s, in stock sizes, I am pleased with the SO-3s. Grippy, reasonably quiet, good in the rain. Seemed nicely controllable during my one and only AX but I don't have any reference. Dash If you're going to keep the car a while, might as well replace the dash pad while you can still get them easily. Will help resale too. Keep an eye out, at swap meets or dismantlers, eventually you'll find one for $100-200, or I think PP sells them new? The part of the install that involes the windshield R/R sounds a bit daunting but people have reported DIY success. Actually, the success rate (of R/R'ing the windshield without breaking the old one and with a good fit on re-install) seems to be higher for DIY than for folks who used a commercial auto glass company, based on reading BBS posts. Do a search - too many stories of commercial glass companies that broke the original glass and glued in the new one with big gaps and big sloppy gobs of sealant. Aside from the windshield, the R/R of the dash pad itself is simple, I did it recently on my '89. Take the time to properly remove the gauges, vents and knee pads for better access to the retaining nuts, and there'll be relatively little cussing. |
205 55 16 and 225 50 16 will be good stock choices for tires. If you had 16x9's in the back then maybe 245 45 16.
Bridgestone S-03's are great tires, BF Goodrich gForce KD's are supposed to have the best dry stick I have been very happy with the Bridgestone RE 730, but that has been replaced by the RE 750, so I can't say about that tire. |
Whatever you do don't go Pirelli - just got rid of mine after 5000km.
I was at a shop yesterday where the guy raved about the S-03's. They are too $$$ for me. I was also surprised to hear that some Porsche's are coming out of the factory with upper end TOYO's. I just put on Michelin Pilot's - XGT H4 (stock size) on my lowered 79SC. Very happy with them and fine for my spirited drives off the track. Good wear expected. I've heard non-stock sizes on rear can burn out your diff depending. Guys here can comment further as I am no expert. |
Re: Re: SC Dash & Tire questions
Thanks everyone for all the helpful suggestions. |
Running non-standard diameters (225/45 on front) will affect the suspension geometry, the radius of a wheel is part of the overall design. In this case it probably isn't such a radical change that you will have any trouble with it. I'm running 205/55-16 and 245/45-16 on my SC and it helped eliminate a tendency to oversteer under power; each car is different, YMMV. I am running S-03s, AVS Sports, Ecsta 711s on different beasties, the 711s are pretty darn good for $44 ea, the S-03s seem to always develop flat spots when parked for a few days but have good grip that gives up nice and gradual, the Sports have a steel sidewall ring and are very snappy. |
I will eventually install a new dash pad but only as part of a re-paint. |
| All times are GMT -8. The time now is 12:00 AM. |
