-   -   highbeam indicator light doesn't work (http://forums.pelicanparts.com/porsche-911-technical-forum/123961-highbeam-indicator-light-doesnt-work.html)
krichard 08-18-2003 09:58 PM
I am going to get my car inspected tomorrow and noticed tonight that the highbeam indicator light does not work. I pulled the od and the tach and checked the bulbs and they are fine. I looked at the fuse box and the wire looks to be hooked into the highbeam fuse. I am not sure where to go from here to debug the problem. Anyone know what the path of this circuit is?
350HP930 08-18-2003 10:07 PM
Are you SURE that the bulb and pigtail assembly are OK?
Some bulbs will look OK but be burned out and sometimes the contacts in the pigtail assembly can corrode to the point of breaking the circuit.
krichard 08-18-2003 10:10 PM
I changed out the od light with another constant light on the gauge that I know works, I didn't try replacing the one on the tach but looked at it closely and it looks ok. Do they both have to be good?
bigchillcar 08-18-2003 10:22 PM
Kerry,
Are you absolutley sure it's burned out? Mine is so dim that it isn't visible during the day and still quite dim at night. I'm sure you're right, but thought I'd mention this.
Ryan
krichard 08-18-2003 10:34 PM
Ok I'm a dumb ass. I changed the one in the tach and what do you know I get indicated!!! What is the light in the speedo for?
350HP930 08-19-2003 04:23 AM
Fog lights only.
Hetmann 08-19-2003 08:36 AM
How did you get the indicator light out of the back of the tach? Mine is stuck in there pretty good and I'm afraid I'm going to break something.
david914 08-19-2003 09:19 AM
The light at the top of the speedo indicates that just the parking lights are on. It goes out when you switch on the headlights.
techguy 08-19-2003 10:07 AM
High Beam Light
Check the plastic..mine has gone so dark not even the brightest bulb works.
Pete
Eric Coffey 08-19-2003 11:33 AM
you can either try to get a sharp tool/screwdriver between the gauge housing and the metal bulb sleeve, or find a pair of pliers and twist the metal sleeve out.
SmileWavy
