Shawzy's Avatar
Exclamation Check your CV joint bolts
Bolts had loosened on one my CV's - re-torqued.
Just thought I would post as a friendly reminder as these bolts are known to loosen apparently. Thinking of drilling and wiring mine for extra safety.
If opportunity doesn't knock, make a door.
Old 08-19-2003, 12:04 PM
Somewhere in the Midwest
MotoSook's Avatar
Yep, they loosing sometimes. I found this out years ago on a farm road far from home. Got off the highway and the first railroad crossing resulted in a sudden loss of power. Oh oh! Now what!?! Coast to the side of the road and check the engine bay. Nothing funny there. Revs OK. Sounds OK. Looked under the car to find a dangling half-axle with twisted bolts!
Luckily I had traveled that road before and was aware of a gas station about .5 miles down the road. Got towed there and had to instruct the resident wrench what to do…guess he was use to pick’em up trucks But they were very nice about everything. I was lucky.
Now I check them frequently and am considering drilling and wiring the bolts.
Old 08-19-2003, 12:29 PM
I replaced the bolts on my '75 a couple days ago because the old ones were getting stripped.
I'd never done a 4-bolt CV with the M10 bolts before...boy, do those things take a lot of torque! 61lb! I thought I was going to break the things, but they held.
Thanks for the reminder
Old 08-19-2003, 01:14 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Can thin lock washers be used to keep them from loosening and spinning out?
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 08-19-2003, 01:23 PM
Non Compos Mentis
Remember Skinnerd's post a while back?
Seems as if it's not a good thing to have a loose shaft banging around your new SSIs.
I'm going to check mine when I get home.
Old 08-19-2003, 01:31 PM
CHILI's Avatar
I have lockwashers on all of mine. One is an american style, the rest are the German type. Put new boots on about a year and half ago. Interestingly enough, I checked them this past weekend. Seems like we are on the same wavelength! Still tight.
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 08-19-2003, 01:52 PM
Randy Webb's Avatar
re safety wires -- I'm still concerned about drilling holes in the heads -- they aren't that big, and tho some have disputed this on the basis of hole size, I'd be worried aobut stress cracks propagating.
Note that lubing the threads can alter torques and hence how "tight" the bolts will be.
Old 08-19-2003, 06:30 PM
Schnorr washers. torquing my axel
Argo
88 Targa
Old 08-19-2003, 06:38 PM
Bill Douglas's Avatar
LOL, I used Schnorr washes and Loctite. After I had used the Loctite I thought "Opps maybe that wasn't such a good idea ".
Old 08-19-2003, 06:42 PM
drilling the heads of the bolts wont weaken the bolt itself, dont worry about that. Just be sure to deburr the holes or even add a small chamfer so the wire wont get cut.
A .040 hole will be fine. Use .030 stainless wire.
you are good to go at that point
Old 08-19-2003, 07:32 PM
