Ho Hum 74's Avatar
How do you remove the dust sheilds?
Hi gentlemen,
I have done a search on "dust sheilds" but not found what I'm after. Can someone tell me what the procedure is to remove the dust sheilds from the brakes?
Tristan
Old 08-21-2003, 11:10 AM
For the fronts you have to pull the tire, then pull the bearing cap, then pull the bearings and hub, then there are three bolts that hold the thing on.
The fronts are, I think a little more complicated, but I've never done it myself so I can't say for sure. If you have to pull the big nut then it's probably a big pain, but if you do not have to pull the big nut then it's probably not too much worse than the front. I think you have to pull the big nut.
Old 08-21-2003, 11:28 AM
ruf-porsche's Avatar
I think you are referring to the dust shield for the spindle that the rotor is mounted to. Tap around the dust shield evenly with a hammer, as if you were trying to knock it from the back out.
Old 08-21-2003, 11:29 AM
tear it down until the rotors are off, then unbolt them.
206 637 4071
Old 08-21-2003, 11:30 AM
Ho Hum 74's Avatar
ruf-porsche,
And this will remove it? I thought it was bolted in.
Tristan
Old 08-21-2003, 11:46 AM
Is it number 33 that you are trying to remove?
Old 08-21-2003, 12:01 PM
Ho Hum 74's Avatar
33?? I'm trying to remove the dust sheilds from the front and rear brakes.
Old 08-21-2003, 12:02 PM
As the others pointed out, to remove the front you have to remove the hub assembly. To remove the rear just unbolt the dust cover.
Old 08-21-2003, 12:06 PM
Ho Hum 74's Avatar
ruf,
Too funny, when I wrote my reply your picture hadn't quite loaded yet! Sorry if I sounded a little abrasive when I couldn't see the pic.
Tristan
Old 08-21-2003, 12:07 PM
So is it no. 33 in the diagram that you are trying to remove?
If it is follow my previous advise, if it is the the shield behind the hub follow everyone else advice.
Old 08-21-2003, 12:10 PM
Ho Hum 74's Avatar
ruf,
Actually it's the rear sheild I want out of there.
Thanks though.
Tristan
Old 08-21-2003, 12:12 PM
Early_S_Man's Avatar
Porsche Crest
Three M8 bolts on either end, and you are done!
Very easy on the rear ... caliper and hub must come off for the front!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-21-2003, 02:18 PM
