-   -   SC injection leak - advice please!! (http://forums.pelicanparts.com/porsche-911-technical-forum/124234-sc-injection-leak-advice-please.html)
dude 08-20-2003 07:50 PM
I've got a minor bit of fuel wetness on the top of 1 injector just below where the fuel line screws onto it. It appears the injector sits in an o-ring. How is this removed from the intake pipe(engine in car - right rear cyl so access is good.)
Could this cause a very slight backfire - I mean slight, at cold start up. Doesn't happen warm. Idle is up/down for 45 secs until warm, then settles down to a fairly even 950 rpm.
Thanks!
MotoSook 08-20-2003 08:06 PM
"reseat" the injector connection and the leak should go away. I'd take the injector out and try to clean the mating surface too. With a vise-grip and rag, clamp injector and pull straight up. You could take line off first.
Backfire at startup is common.
