Anyone done a 3.0 swap into a 72T MFI?
Hi there.
I'm looking for some wiring help with my engine swap. If you've done one, please let me know. Thanks, mto |
Anyone?
bumpity bump
Someone out there knows something... help the guy out.
I'm thinking about the 3.2, many differences ? |
Thanks Nigel.
Hey everyone...listen to Nigel!!! |
What wiring help specifically?
I am nearing the completion of the installation of a 3.2 in a 72' chassis...I have a simplified wiring diagram posted in a link from this page: http://brentwoodrocketscience.com/r2/notes.htm
Hope it helps. Jack McAllister |
Jack - what an outstanding engine :D :D :D
Please let me (or the Board) know how well the MSD timing computer works!! Cam |
Here are my posts about the wiring help I need.
http://forums.pelicanparts.com/porsche-911-technical-forum/123869-need-wiring-fuel-oil-connection-help-part-1-a.html http://forums.pelicanparts.com/porsche-911-technical-forum/123871-need-wiring-fuel-oil-connection-help-part-2-a.html Jack, where did you get the plug/pin settings? Did you have to trace them from a wiring diagram? I've got the two separate plug/pin settings drawn, but I'm not sure what goes where. Your post helped immensely. Thanks, mto |
I used a combination of the factory service manual wiring diagram for the pin locations for the 72' and a diagram for the 84' engine from a posting on this board. I found the latter by doing a search for "14 pin" in the tech BBS (as I recall)...
Good Luck, Jack |
thanks Jack. I'll do my best.
Cam,
I didn't see your post...Thanks. The 3.2 and trans was installed in the chassis last weekend. I am moving the car from my Dad's garage in Gainesville, GA to Atlanta tomorrow so I can deal with the MSD components and the setting up of the PMO's at my home without distractions. It should be ready to start in a week or two. I'll post a short digital movie on the website documenting the startup. And yes, I'll share the details of the timing computer performance once it's dialed in and a few miles are logged on the odometer. Jack |
| All times are GMT -8. The time now is 10:22 PM. |
