 automatic thermostat control fix?
		Without getting too involved, is there an easy fix/check?
	The knob (on consule, between seats) turns and clicks but I get no fan or heat, never have. I'm heading out of town next weekend so I don't want to take the whole unit apart and end up "breaking" something before I go. I just thought that maybe there was something obvious I could check? The heater pulls work fine.  |
 from the workshop repair manual:
	http://forums.pelicanparts.com/uploa...1061442199.jpg http://forums.pelicanparts.com/uploa...1061442217.jpg I am sure there will be some firsthand knowledge coming soon. good luck, max  |
 Thanks, Max.
	I did a search and I realized I may NOT have the automatic heater. The two levers I can and do pull up manually. The center knob I guess is for the defrost. When I pull the two levers the footwell motors do work, so I quess the blower motor (under engine hood) IS working because I read you can't have one work without the other. However, when I turn the defrost knob I get nothing. I've only been testing this desfrost without the two levers pulled - do I need to work them together? Would I even know if the defrost knob works, ie more heat or different vent? From doing the search along with just reading my own idiotic sounding question, I'm amazed how a few levers and a knob can be so confusing, not even counting the levers on the dash!  |
 Bump.
 Bump 'a bump bump.
| All times are GMT -8. The time now is 07:04 AM. |
