3.2 Spark Problem
I swapped a 3.2 into my '76 a couple of months ago and have been chasing a hard starting problem ever since. Once it starts, it runs great - just getting it started is the hard part.
I have gone through and checked nearly everything (all components, voltages, resistances, pressures etc. are in spec), but was goofing around last night and thought I would see how strong the spark was. I found the problem... When the car is cranking, there is *no* spark. Only when the key is released (back to the "run" position) does a nice, strong, blue spark jump the gap. I have spent some time looking at the wiring diagram, but so far nothing is jumping out at me. Anyone have any idea what could cause this "no spark when cranking" problem? Thanks, Mike |
ignition sw?
but there is a leg on the sw. that does not supply current in the "start" mode.. it'll only supply current in the "on" position. again it's only a guess on what may have happened during the install for feeding the DME........Ron |
Well, I hesitate to suspect the ignition switch since the car cranks properly (starter spins).
Mike |
As mentioned by Ron it is most likely how the DME harness (chassis side) was integrated into the car
Tem 86 on the DME relay is a switched ignition source. Depending on where you are picking that source up it may not be getting 12V while cranking. There are several circuts to which power is shut down going from the run position to cranking position on the ignition switch. Todd |
Thanks. I've got some things to check, but it seems that - for whatever reason - the DME isn't getting powered during cranking....
Mike |
You might want to PM marcesq to review what you did in the conversion. He did a 3.2 conversion that seems to have worked out fine.
Thanks, Mike |
if the DME is getting current from the ignition sw leg that's NOT supplying current during the "start" position, Then blah, blah, blah |
| All times are GMT -8. The time now is 08:08 AM. |
