-   -   New Starting Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/124325-new-starting-problem.html)
jhoughton 08-21-2003 01:47 PM
When I go to start the SC, it will fire and then die immediately. I go through this a few times before the engine stays running. Once is finally starts, it will go through a normal warmup (increased idle for a couple minutes) and then settle down. Any ideas? Could it be the WUR?
RoninLB 08-21-2003 09:54 PM
I don't know much about the SC CIS..
how about the cold start valve and its wiring
fogcity 08-21-2003 09:56 PM
Needs a "tune up"?
MotoSook 08-21-2003 10:29 PM
Yep! Sounds like a little CIS tweeking is in order.
After warm up...does it run rich? Lean?
jhoughton 08-22-2003 08:10 AM
I have already done a tune up about 4k ago. After the car starts and stays running everything is fine. The CO levels are right on that is why I am leaning towards the WUR. Any more thoughts???
Doug Zielke 08-22-2003 08:33 AM
As mentioned here *many* times before, you can't do very much CIS troubleshooting, without a pressure test kit.
