Ok,
I did document all wiring except this one... Missed it and had to remove it "quickly" during the enginge drop. It happens ![]() Can anyone tell me how I can know how to connect it correct ? One is ground ( I assume as it is yellow/green ). Btw the transmission mount will be dealt with during the winter.... Now I want the car back on the road before the polar bears hits the street.
Brandett,
I am not sure that it matters. The switch is a continuity switch, as the contacts close, the circuit is completed, this is either a voltage through , or earth continuity, in either case, the wires can be in either socket. Regards Hayden. |
Somewhere in the Midwest
yep...just a contact switch... for the back up light
Great, then I am ready to install the engine into the car !
Thanks. |
