oil pressure sender on an early engine.
i have a '67 2.0 in my 914-6. i'm wanting to install a 911 combo gauge, temp/press.
i've got the temp sender by the fan and the pressure switch by the case vent.
there is not a fitting on the cam oil line for a pressure sender, as i have seem on the later engines.
i've seen fotos of early engines that have what appears to be a pressure sender in the same location as the switch.
is there a dual pressure sender/switch??
know the part #??
TIA,
doug waters
doug waters
70 914-6
dougwatersfotos.com
http://www.flickr.com/photos/dougwatersfotos/
Old 08-25-2003, 04:05 PM
Early_S_Man's Avatar
Porsche Crest
Doug,
There is a VDO dual sender/switch available, but it isn't a factory part ... and the threads are a tapered M10 x 1.00 [like a pipe thread] ... rather than the parallel M10 x 1.00 threads of the factory Porsche 0 -150 psi pressure sender. Not a desirable solution, IMHO!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-25-2003, 04:27 PM
thanks warren!!
can the switch be replaced with a sender? and just lose the idiot light?
thanks, doug
doug waters
70 914-6
dougwatersfotos.com
Old 08-25-2003, 04:36 PM
