-   -   late '73 trailing arms (http://forums.pelicanparts.com/porsche-911-technical-forum/124717-late-73-trailing-arms.html)
blue72s 08-24-2003 10:38 PM
I understand that sometime in late '73, RS trailing arms were shortened for improved handling, but I don't know if T, E and S models also received this upgrade? Anyone know?
If so, what was the earliest VIN# fitted with short trailing arms?
Was this upgrade significant improvement?
thanks
GeorgeK 08-24-2003 11:13 PM
The very few last RSs had the shorter rear railing arms, like the RS 3.0, and the RSR 2.8. VERY rare.
GeorgeK
blue72s 08-25-2003 09:37 AM
Thanks George.
Did any of the post-'75 cars have this rare short trailing arms?
Can it be retrofitted to any LWB 911?
Got any photographs showing the difference?
GeorgeK 08-25-2003 09:52 AM
I *think* they are very similar to the 930 arms. To fit these, you have to alter the anchor points on the shell.
The steel arms on the RS are absolute unobtainium.
GeorgeK
JSDSKI 08-25-2003 10:00 AM
The short trailing arm set up is not recommended for street use because it reduces straight line stability. Which is why it wasn't seen on later production cars - even as a "sport" or "RS" option - only on some track cars. There are photographs and a paragraph or so about it in B Anderson's book under "Suspensions".
