-   -   Engine Stand Spec Needed! (http://forums.pelicanparts.com/porsche-911-technical-forum/124902-engine-stand-spec-needed.html)
DKW 08-26-2003 10:50 AM
HI all
Does anyone have any spec/dimensions for building an engine stand for my 911's motor?
ChrisBennet 08-26-2003 11:58 AM
Do you need the diameter of the yoke i.e. the part that bolts to the engine and gets inserted into the engine stand?
You can't make the yoke itself as cheaply as you can buy it - maybe even with a machine shop at your disposal.
-Chris
trak ratt 08-26-2003 01:38 PM
The receiver/yoke is usually round 2” ISD stock. I like a little taller neck so 34” or so. Cross peace about 24-30”, w/30-36”legs. Use 2” stock w/at least 2”casters. Trick it out w/a splash tray across the legs & a tool tray behind the receiver. In the US you can buy a basic 1000lb capacity stand for under $50. Can’t hardly make one for that.
tiorio 08-26-2003 01:47 PM
Since we're here, anyone built a stand to run the motor on as well?
North Coast Cab 08-26-2003 06:05 PM
Look at Wayne's Engine Rebuild Book, the 2.7 is mounted in a stand which can run the engine.
JG
