turn signal relay
Where is the turn signal relay on an 87 Carrera? My signals are not working on two of my cars! If I jiggle the relay and it works for a few seconds, is it a bad relay or a bad connection?
I had same problem with my 83SC.
Turn signal relay is right behind your oil temp gauge, you can either pull the guage or access it from your trunk. I took my relay apart and foud a bad solder joint, re solderecd the joint and it has been working fine ever since ! Good Luck. |
| All times are GMT -8. The time now is 02:05 AM. |
