Headlights electrical
I just installed a pair of H4's in my 77 911s. Low beam seems to be more on the yellow side compared to hi beam. Is there a ground for the low beam side that is seperate from the hi? I just feel like I'm not getting all the light I should be.
Old 08-27-2003, 12:45 AM
Senior Member
Jdub's Avatar
Be SURE you install a relay kit for those headlights. Use the Search function and search on "Sucro" to see information about this excellent kit (around $20.00).
I cannot comment on the low versus high - just don't know if there would be separate grounds for each (doubt it). This *might* be related to a signal stalk going a bit bad on the low light side?
Get those relays in though. If you don't you will fry the contacts on the signal stalk.
John
'78 Targa in Minerva Blue
Old 08-27-2003, 07:45 AM
Same ground (3 pin connector on the back of the H4 bulb). And what John said re: relays. Get 'em. Your headlight switch will thank you for it.
Chris M
1985 911 Carrera w/ 3.6
Old 08-27-2003, 06:03 PM
47silver's Avatar
pelican sells the relays i think 9 bucks?
gary
1975 911S Targa
Silver Anniversary Edition
Old 08-27-2003, 07:25 PM
