Question Turbo removal help...
I'm trying to disconnect the headers from the turbo itself.
It looked easy enough with just 4 bolts, but the space is soooo tight that I can't really get any wrench in there; let alone 2 (to hold the nut & bolt).
Any suggestion from those who had done it? And - what's the size of the nut? I tried 13/14mm but neither seems to fit
thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 08-28-2003, 06:30 AM
pulling off the bumper has made a lot of folk's lives easier. the wrench size can vary, 14 and 17 is common. yes, it's a pain sometimes.
206 637 4071
Old 08-28-2003, 08:02 AM
Thanks for the advice - good as always
And just as I thought - maybe the bumper has to come off Not having done it before, is there any tricks / things to watch out / where to start advice that you can provide?
Thanks again...
Old 08-28-2003, 08:15 AM
To remove bumper remove 4 8mm nuts from their studs on the inside of the bumper. These (2 on each side) hold one edge of the rubber accordion on. Pull the accordian studs away from the bumper until they are out of the bumper holes. Then remove the two rear black bumper gaurds (you can search for instructions on this. It involves removing the reverse lights, unplugging the wires, then removing the mounting nuts on the inside of the bumper. The narrow trim strips need to be pulled back first.)
For the turbo, I had to use a stubby wrench, crowfoot wrench, and beer. 17mm on mine.
Good luck!
Old 08-28-2003, 09:30 AM
Jocke's Avatar
Send a message via ICQ to Jocke
First time i loosen mine, i go crazy too, but if you take away the "heet-shield" mounted right above the turbo you get plenty of place to take away the last bolt from the inside of engineroom. (at least on my 3.0L 930 i think it's the same on yours)
/Jocke
Jocke Andersson
Reach me on ICQ - 317860713
Porsche 930 -77 SOLD
Modified, one of a kind in Sweden.
Check out my car @: http://members.cardomain.com/jocke
Old 08-28-2003, 12:30 PM
Send a message via AIM to Supergranule
hey, Patrick T, I am also a Patrick T
Old 08-28-2003, 02:31 PM
Good to see there's more than one of me out there...
I'm going to first attempt loosening the nuts around the header first tonight then will get to the turbo. Will report back on progress soon.
Old 08-28-2003, 02:46 PM
Still struggling with the darn thing but now I also have a 2nd problem - what tool do you use to get those 6 hex nuts off the headers (where its bolted to the exhaust ports)?
Will a crow-foot socket work? Someone told me that if you bought the SSI headers, it comes with a specialty C-shape one to do the job?
Thanks again...
Old 08-30-2003, 07:21 AM
crowfoot or offset wrench will do (6 point will be safer). Socket and universal joint almost never works.
Old 08-30-2003, 07:31 AM
