If I add SC flares ,do I also need different rockers?
I have a 77 911s with standard (Non SC) flares. I'm looking at adding SC flares in the rear and the RUF ctr f/r bumpers from BW.
If I do this, do I have to change the rocker panels as well or will the 911s rockers work? I remember seeing another thread where someone said if you use the RUF CTR f\r bumpers ,you should remove the rockers all together ,to make it cleaner????? Thanks Rick |
Personal taste aside, the one thing that is certain is that your existing rockers will not work.
You'll either need aftermarket rockers, SC/Carrera rockers, or no rockers at all. |
| All times are GMT -8. The time now is 11:58 AM. |
