Hack Mechanic
rsiegel's Avatar
Does Anyone Have a Sanden 508 Compressor Installed?
I'm replacing my York a/c compressor with a small, modern compressor. I see from reading this board that many folks use the Sanden 507 and a York to Sanden adapter bracket. Is there anyone who has successfully installed the larger Sanden 508 or 510? There are other manufacturers (e.g., Seltec and Unicla) who make compressors in both the 507 and 508 form factor, and I'm trying to learn whether ONLY the 507 dimensions will fit. I'll write this all up as a very detailed post when I'm done. Thanks.
BMW CCA Roundel Magazine, "The Hack Mechanic"
Author, five books available on Amazon
Personally inscribed books available at www.robsiegel.com
Nine vintage BMWs and a dead Lotus Europa that seemed like a good idea at the time
Old 09-01-2003, 05:23 AM
walt's Avatar
I installed a 507 earlier this summer. My understanding is the smaller compressor (507) was better suited to the condensor area of the 911. Unless you add an underbelly condensor you proably won't gain much cooling capacity from a larger compressor.
Walt
82SC 3.0
81SC 3.6
Old 09-01-2003, 06:00 AM
Hack Mechanic
rsiegel's Avatar
Thanks Walt. I'm looking at the 508 and 510 not so much because of their larger displacement but because they're still available and they show up fairly regularly on Ebay, whereas the 507 appears to be out of production. On my car, a compressor the size of a 508 appears to hit the intake manifold. I'm trying to figure out if this is a quirk, or if other people have in fact successfully mounted a 508.
--Rob
Old 09-01-2003, 06:20 AM
I had a 508 compressor put on my SC this year by TRE and in order to get it to line up correctly the manifold bracket that is solid needs to be ground back.
I'll get some pic's for you in a little while.
Old 09-01-2003, 07:49 AM
Sorry, thought it was a 508 but it's a 507.
Old 09-01-2003, 08:42 AM
fred cook's Avatar
Cool A/C compressor
You have a PM from me about the Sanden compressor.
Fred Cook
Old 09-01-2003, 08:49 AM
