Interior Light
My interior light only comes on when I put it in the forward position or the back position. I want the light turn on when the door opens but it doesn't do that. I've tried the middle position but no luck. Should I replace the light? Would it be better to replace the whole unit that is faulty?
Friend of Warren
Sounds like the light is working just fine. I suspect the door switch is faulty or needs to be cleaned.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Mine works when the doors are opened, but not when switched manually; I've taken apart and cleaned - no change. Any thoughts?
79 sc - Minerva Blue |
the light has a chassis ground..
push the housing to the rear to remove tension on the front of the light to remove. Run a chassis ground wire to the light rear ground spring clip.. then test the light in all positions when removed..............Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
