High Beams MIA
The high beams on my 69 911T have taken a sudden vacation. The low beams work just fine, but no high beams, high beam indicator, or headlight flash. There is no current at the high beam fuses. I can't seem to locate a 69 wiring diagram, but the 71 wiring diagram here at Pelican seems to show a headlight relay.
I've read the various threads about this problem, so the turn signal/high beam-low beam switch is definitely a suspect. However, before dissecting said switch, I'd like to check out the relay, and clean the various contacts. My question in a nutshell...where the hell is it located?
Any help would be appreciated.
Thanks,
Dave
1969 911T Coupe (currently none too bright)
Old 09-02-2003, 01:28 PM
Kantry Member
oldE's Avatar
The relay (s) can be found in the front trunk, left hand side.
Les
Old 09-02-2003, 02:00 PM
Senior Member
Superman's Avatar
Relays do not run the headlights, and that's the problem. My guess is the switch. Checking the current diagram, see if the juice to the fuse comes from the stalk switch. If it does, then see what wire feeds the juice to the stalk switch. If it's getting juice but not passing it on to the fuse, then you have your answer.
"Juice" is a technical term for electricity, generally used only by highly trained electro-technicians, like myself of course.
Mocha 1978 911SC. "Coco"
Old 09-02-2003, 02:04 PM
joehahn's Avatar
there you go: Early Seatbelt Pics Needed
see the tail end of this string. cars are 68s but location i believe is the same.
joe 68 L
Old 09-02-2003, 02:05 PM
joehahn's Avatar
aaah, just saw that superman provided a good point. in that case let me direct you to another dilemma of mine: electrical "ground" question (fixed...but still have question) this is great, the more crap that goes wrong for me, the more helpful i become.
joe 68 L
Old 09-02-2003, 02:11 PM
Early_S_Man's Avatar
Porsche Crest
Dave,
All early cars ... from day 1 thru '77 models had a relay ... yours should be near the fuse block [and left battery] up front in trunk area.
The following diagram is not your year, but the color code and wiring should be the same:
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-02-2003, 02:14 PM
Senior Member
Superman's Avatar
nevermind.......
Old 09-02-2003, 02:17 PM
Thanks Les, Superman, Joe & Warren, for the help.
My cynicism wouldn't let me believe that the relay by the fuse blocks would be the one. I figured it was probably somewhere that involved contortionism and band-aids. I'll check that tomorrow, and if not, off to the switch.
BTW, if the relay is bad, what's the proper replacement? I see 2 relays advertised at most parts sources, neither of which mentions headlights as a function.
Thanks again,
Dave
Dave
1969 911T Coupe
1972 911E Targa
Old 09-02-2003, 05:58 PM
Porsche Crest
Dave,
Black round relay that is also used for horn and factory fog/driving lights ... '911.615.109.01' relay
Fog Lamps, Horn, etc., Black round, 911 (1969-89), Each C-615-109-01 $18.85
Warren Hall, Jr.
Old 09-02-2003, 07:06 PM
joehahn's Avatar
warren, any thoughts on where i can get the 68 three prong relay in the other post? i too have the hella and can't find it.
Old 09-03-2003, 05:14 AM
Warren,
Thanks for your help..off to surgery.
Dave
Dave
1969 911T Coupe
1972 911E Targa
Old 09-03-2003, 05:38 PM
