Driving member
Brake rotor question?
I am probably going to be doing new brake pads and possibly new rotors in the front pretty soon.
Do the new rotors need to be turned before I put them on or are they good to go out of the box?
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Generally rotors are good to go out of the box. A run out gauge can be used prior or after install. If they feel smooth on your test drive they're gonna be ok, if they thump or what ever and you didn't check them prior, then ther're defective or need to be turned.
1991 964 C2 -SOLD - miss it everyday - ![]() 2009 Honda CRV 2007 Audi A4 Quattro - just a sweet personal car - 2000 Land Rover Disco II - lifted 2001 GMC Seirra 1500HD CREWCAB |
Driving member
Thanks 91C2wrencher. I thought that was the case but a friend of mine said he thought I might need to have them turned.
Here's info for bedding in new pads and rotors (there are two different FAQs):
http://www.wilwood.com/products/techtiplocator.asp
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Diss Member
As 91C2wrencher said, unless the rotors aren't true or have bad gouges, just run them the way they come. They will be blanchard ground (non directional grinding) which is definitely the preferred surface prep for a rotor.
A lathe turned rotor is not the best way to ever surface a rotor. It is just cheap and easy to find some one to do it. Wayne
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
If they need to be turned take 'em back and get a good pair. Make sure you clean off the packing oil from shipping.
Have fun! |
nice avatar....
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
