What's Facebook?
turborat's Avatar
SS Braided chain tensioner oil lines
I have been considering replacing the hard lines for the chain tensioner on my 3.0l to braided hose. These hard lines are soldered to the ball and I’ve experienced untimely breaks while on track. I’m thinking 2-an hose and sourcing the metric adaptors for the oil line up top and the banjo below. Before I recreate a wheel, has anyone sourced the fittings or found hoses already put together.
Cheers
Turborat
"’Cause every once in while, the lion has to show the jackals who he is”
1979 911 SC - 2100 LB track rat
1986.5 928 5-Speed - 36,000 miles
2001 330Ci
Old 02-01-2021, 06:36 AM
BoxsterGT's Avatar
Porsche Crest
There are normally some "anti-vibration" supports to keep this from happening.
Do you have them or are they failing even with the supports?
Len
Old 02-01-2021, 06:47 AM
What's Facebook?
turborat's Avatar
Len
Len, the adel clamps are installed. Engine and trans are on solid mounts. The lines seem to last about 3,600 track miles which in time is about three years. I’ve included them in my pre-tech inspections, and never caught a potential failure.😡.
Paul
Old 02-01-2021, 07:02 AM
Greetings Len!
I sent you a quick email as your inbox is full.
Thanks,
DJ
Old 02-01-2021, 11:09 AM
