-   -   Reverse gear crunch?! (http://forums.pelicanparts.com/porsche-911-technical-forum/126067-reverse-gear-crunch.html)
moazam 09-21-2003 08:36 PM
Originally posted by Wayne at Pelican Parts
Not normal (as Warren said). Wait 10 seconds with the clutch pedal to the floor before shifting into reverse. If it still grinds, your clutch cable is misadjusted, and you are wearing out *all* your synchros prematurely. Or, the clutch is dragging like John said...
-Wayne
If I just wait 2-3 seconds, and/or blip the throttle a bit, it goes into reverse without any trouble. Looks like I'm OK...
Thanks to all for the feedback.
pmax 11-09-2014 04:38 PM
Originally Posted by GrindingGears (Post 943425)
Read your Porsche manual. Mine states to press the clutch down for a second or two before shifting into reverse. Mine does the same when I rush to shift. No worries.
-Grind
Like the OP, I experienced this 915 feature today :(
I'm surprised no one brought this up in any of the longwinded 915 vs g50 discussions.
Rich Gas 11-09-2014 07:10 PM
It's a true racing gear box, unlike the G50.
Hugh R 11-09-2014 08:07 PM
Clutch adjustment first, before you do anything else.
pmax 11-09-2014 08:47 PM
Clutch was adjusted recently.
Checked the manual and it indeed says to hold clutch down for several seconds before shifting to reverse. I am quite sure I didn't do that.
I'm just a tad surprised by this.
Nick Triesch 11-09-2014 10:25 PM
When I was young it was called "Clearing the gears". My Brother showed me when I was about 12 in a new Corvair. You just go to first , move a tiny bit forward and reverse goes smooth right in. I have done that with many cars all my life.
