Need source for 4x6 speaker covers
Hello all,
I replaced my original rear speakers with a set of Infinity 4x6's. They sit up a little higher due to the thicker mounting plate and my warped original grills just look bad. Where can I find some grills that will fit better and look ok too? Maybe my other option is to try to mount the speakers from the bottom, then find some original grills in good shape. Opinions, thoughts, etc. Thanks! |
I put mine (Infinity Kappas) in through the bottom and used the factory grilles (although they were cracked). Looks stock. It's an '86 coupe though -- don't know if the Targa rear deck is different.
Chris. |
me to the rescue........can you post a pic of the speaker you have? i have a few different types of 4x6 grills but need to know the clearance you need, they're yours......just cover shipping :)
pm me if you need them |
Bell di d the exact same thing for me..highly recommended. Needed grills for aftermarket 4x6's that fit the stock hole, but were "raised".
---Wil Ferch |
| All times are GMT -8. The time now is 09:33 AM. |
