nigel911's Avatar
Valve stems
Anyone know who stocks the larger valve stems for deep face Fuchs? These are the 'with inner tube' type rims which many of us now use without tubes.
All help and pointers gratefully received.
Old 09-08-2003, 03:26 PM
I've been dealing with the valve-stem question recently, because at the last track event I drove--just a DE, but at Watkins Glen, a fast track--the front wheels got hot enough from the brakes that the sticky tape holding in place the little tabs that hold the rubber valve stems against centrifugal pressure melted and the tabs slid out of position enough to be useless.
I asked my friend Steve Weiner whether these valve-stem tabs are just cosmetic go-fast items or are useful. He assured me that they are indeed useful and necessary, if you're going to be doing 140+ speeds, and that Porsche developed them for the original Turbo.
But more to the point is the fact that nobody who plans to go fast should be using rubber passenger-car valve stems in any case. I plan to replace my rubber valve stems with chrome-steel stems intended for racecar use...if that's of any interest to you.
Stephan
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-08-2003, 03:55 PM
Valve stems are the leading cause of tire deflation. I would strongly suggest metal valve stems as Steve suggested as well as good quality metal valve caps.
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood.
Ayrton Senna
1993 964 RS
Old 09-08-2003, 04:10 PM
Friend of Warren
To add to what JP said, look for metal motorcycle valve stems, the are very short.
Kurt V
Old 09-08-2003, 04:23 PM
Yup, that's exactly what I was told by a variety of sources--motorcycle stems.
Stephan
Stephan Wilkinson
Old 09-08-2003, 06:08 PM
nigel911's Avatar
Thanks guys, but where would you buy them?
Old 09-08-2003, 06:24 PM
Harley dealer, local motorcycle shop...they gotta be all over the place down there in Florida.
Stephan
Stephan Wilkinson
Old 09-08-2003, 06:39 PM
Bill Douglas's Avatar
I've been using the motorbike ones for the last 9 years. they are great. There're only about 15 or 20mm long and are too short to be able to flex.
Old 09-08-2003, 07:04 PM
nigel911's Avatar
Thanks for the help guys, now all I need to do is work out how I can make a 1972 911T with a 2.4 do 140mph+...
Old 09-08-2003, 07:08 PM
It's pretty easy actually, just come out of Sunset bend at Sebring at full chat and by turn 1 you'll be pretty close!!
Cheers, James
Ayrton Senna
1993 964 RS
Old 09-08-2003, 07:13 PM
Early_S_Man's Avatar
Porsche Crest
Nigel,
JE 9.5:1 85 mm pistons and GE-60/'S' cams will get you to 140 mph pretty easy!!!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-09-2003, 08:28 AM
