help I need to remove rocker cover
I removed the bolts and gave it a tug but no dice. I how is it attached other than the bolts and screws? It there an adhesive as well? I'm scared I'm gonna destroy them if I pull any harder.
Kerry
'91 C2T
'88 Targa - gone
http://www.pelicanparts.com/gallery/krichard/
Old 09-10-2003, 06:52 PM
JDaniel's Avatar
There are screws under the rubber molding strip & bolts on the bottom. Be sure to remove the end caps and torsion bar-hole cover thingy (sorry I couldn't come up with the real name).
Dan Tolley
1987 911 Coupe
The Owner's Gallery
2006 Audi A4 3.0q Cabriolet
2003 Ford F-150 XL Lumber and Trash Hauler.
Old 09-10-2003, 07:08 PM
Where is that wrench?
EdT82SC's Avatar
I just took mine off this past weekend. I removed the caps on each end, pulled off the rubber strip, removed the 3 bolts along the bottom, and then the 5 screws under where the rubber strip was. Repeat on the other side of the car. There will most certainly be a lot of road grime revealed for you to clean up. I'm guessing it isn't too much difference between your Carrera and my SC.
Good luck!
Ed T.
1982 911SC
Porsche Wallpaper
Old 09-10-2003, 09:53 PM
