Decolliber's Avatar
Replacing Oil Cooler Seal
Noticed a drop of oil coming off the lower oil cooler mount. I assume the seal (Pelican part K-704-173-50) has deteriorated. I thought replacing it would be a simple matter of unbolting the cooler and replacing the seals. But then I looked in Bentley (170-10), and it tells you that you have to partially drop the engine (3") to remove the cooler (in addition to removing the heat exchanger and the a/c compressor!). My experience with Bentley is that it often has you removing more stuff than is necessary to do the job. So here is my question: do you really need to drop the engine 3" to remove the oil cooler? The lower mounting bolts for the cooler are easily accessible from under the car, but I have not check the accessibility of the upper bolts.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 09-10-2003, 05:28 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I dropped my engine a few weeks ago and from looking at it, it would be quite difficult to remove it without at least a partial drop. I've heard this from many others also.
Matt
'82 911SC Targa!
Old 09-10-2003, 05:43 PM
I recently pulled my oil cooler without dropping the engine to clean it.
pictures of engine mounted oil cooler
There was quite a bit of reaching involved, but it can be done. I followed a post by Jim Sims, in which someone was asking the same thing. I was unable to find this post, but it involves removing the right side sheet metal, the plastic shroud extension directing air to the cooler, and then 3 (I believe) nuts holding the cooler in.
2009 997.2 C2S
Old 09-11-2003, 07:27 AM
PCA7GGR's Avatar
I recently replaced the oil cooler seals on a 3.2 installed in a n early '70s 911. It's time concsuming (approx. 2 hours) but can be done with the engine inthe car. A lift helps quite a but since you need to remove the engine tin to get at the cooler.
Sergio
The GT Lid Whisperer
PCA 42yrs - National DE Instructor / Ex-RGruppe #197
'19 718 Cayman S (9th Porsche/1st with PDK)
'14 Subaru Forester XT (Porsche support vehicle)
Old 09-11-2003, 08:17 AM
cooler seals rarely are the problem. most drips on the bottom of the cooler are from the top of the engine at the thermostat o ring, the oil light switch and the breather hose. check back there with a large mirror and a flashlight before potentially wasting your time.
206 637 4071
Old 09-11-2003, 09:33 AM
