-   -   window dimensions? (http://forums.pelicanparts.com/porsche-911-technical-forum/126960-window-dimensions.html)
jpnovak 09-11-2003 06:08 AM
window dimensions?
I am trying to locate some lexan to make my own side windows. I located a supplier that has the abrasion resistant panels. Problem is I don't know how much to get and the car is at home so I can't measure.
Can anyone measure the following window dimensions. They don't have to be precise just within an inch (bigger not smaller)
Front quarter door window
front side door window
rear quarter window
rear window.
thanks
jpnovak 09-11-2003 06:25 AM
Forgot to mention this is for an early coupe. Any pre 964 911 chassis will be fine.
jmohn 09-11-2003 08:45 AM
Here's the glass dimensions from my '78 coupe. These measurements are (roughly) the "visible" portion of the glass, so you'll have to add for the portion of the glass that fits into the seals.
Front quarter (non-movable vent) window:
bottom - 9"
verticle side (nearest door window) - 14.25"
front side - 16.5"
top - 2.75"
Door window:
top - 23"
front edge - 14"
rear edge - 12.25"
bottom - 23.5"
Rear quarter window:
front edge - 11"
longest overall horizontal dimension - 20.75"
Rear window:
top - 37.25"
bottom - 35"
longest overall verticle dimension - 25"
I hope this helps.
Jerry M
'78 SC
TerryBPP 09-11-2003 08:48 AM
Do you know what the name of the Scratch resistant lexan is? I'm very interested to know.
