Sports Purpose 911 Driver
mjshira's Avatar
Unhappy 3.2 experts - please give me your 2 cents
In the past I have posted this problem here and thus far I have done all the things you kind folks have recommended. However, the problem is still happening. So here goes:
Conditions:
1) the car must be at normal op. temp (usually driven for 30 minutes+)
2) after that point the car can be driven with out a problem until the problem happens. This could be 5 minutes or 2 hours. (however it has gotten much more like 5 minutes)
The problem:
The car suddenly loses power. If you give her some gas she'll try to come back but only with some limited success. Then the problem will go away for a few seconds/minutes before coming back. The longer you drive the car the worse it gets.
What I have done:
1) DME relay - changed recently
2) Cyl. Head Temp - change recently
3) AFM - changed today! ;-)
4) timing and crank sensors - changed
At this point I am really at a loss. Anything that anyone change recommend would really help. As you guys can see I've got some $$ in the problem and I want to see it fixed so that I at least feel like I won, you know what I mean?
Thanks ahead,
James
Old 09-13-2003, 01:50 PM
mjshira's Avatar
actually it is more dramatic than I wrote above - the car acts like a bucking bull when this condition happens!
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 09-13-2003, 01:52 PM
911 user
Milu's Avatar
Two more possibilities come to mind:
some kind of contaminant such as a lot of water in your petrol
a minor electrical glitch. have you checked out: rotor arm and distributor cap, plug leads, connections?
I would also check the cyl head temp sensor again. Good luck
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 09-13-2003, 01:59 PM
Have you changed the fuel filter, also, possibly check the inside of the gas tank for contamination.
Old 09-13-2003, 02:12 PM
mjshira's Avatar
thanks Milu. The car has had a complete tune-up. I'll re-check the cyl. head temp sensor.
mjshira's Avatar
fuel and fuel filter have been changed. this has been happening for the last year (I only drive the car about 3K a year at the most). It is only of late that it has gotten worse.
Old 09-13-2003, 02:16 PM
Crusty Conservative
silverc4s's Avatar
Have you removed, cleaned and replaced the ground strap from the trans to the chassis?
Might also check for good grounding of DME box/ good clean contacts in all the DME connectors...;-)
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 09-13-2003, 02:43 PM
Jim Smolka's Avatar
Also, hot wire the fuel pump. This is done by jumpering a red wire in the fuse box to the fuel pump fuse. If this 'fixes' the problem, then look for a 12VDC proplem supplying the fuel pump (DME relay etc).
If the above does not work, then swap out the fuel pump with a know good one.
From there, either clean and adj or replace the speed sensor on the flywheel. The reference sensor should be good, since the car starts well.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 09-13-2003, 06:18 PM
mjshira's Avatar
thanks Jim, what about the coil? Since I have changed everything but the coil, the DME itself and the fuel pump, what do you think?
Old 09-13-2003, 06:20 PM
How bout the throttle valve switch? I had a similar experience some years ago and if I recall I believe that was the cause. They're not expensive and easy to swap with someone.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 09-13-2003, 07:13 PM
Air Medal or two
afterburn 549's Avatar
i vote coil
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 09-13-2003, 07:17 PM
mjshira's Avatar
i just checked Waynes book again. It says that when your fuel pump is loud that maybe a sign that it is ready to be changed. The problem could be the fuel pump going in an out... thanks to everyone for your posts, this is sure adding up to be an expensive process
Old 09-13-2003, 07:21 PM
Check for a vacuum leak. Mine ran like that when I had a vacuum line hooked up wrong.
Chris
'75 911s 3.2 - Ice Green Metallic
‘87 951, '05 987 S
'21 Jeep Gladiator
‘18 Tesla ModelX 100D, ‘20 Model 3
Old 09-13-2003, 07:54 PM
Jim Smolka's Avatar
Chris,
You have a good point, check for vac leaks esp where the small hoses are that connect to the 2 fuel pressure regulators, and there another small vac hose in the center back. Sometimes the intake manifold bolts are not tight.
'81 SC 3.6 (Beast)
Old 09-14-2003, 09:25 AM
mjshira's Avatar
these are all good points. However I want to add emphasis to the point that this problem
a) only happens when the car has been running for a period of time after it gets to normal op. temp
b) it is sporatic - here one second, gone the next.
Old 09-14-2003, 09:50 AM
makaio's Avatar
Does your car have a cat converter on it? I had a ford ranger years ago that had a similar problem because of a bad cat, that was plugged up. It would buck and snort, along with losing power.
Old 09-14-2003, 06:34 PM
mjshira's Avatar
thanks Matt. I do, would yours do this sometimes and then run normally others?
Old 09-14-2003, 06:36 PM
I vote for plug wires, I took off one morning in my 87 carrera and didn't make it a block when it shut down. replace one bad plug wire . 10kmiles since no problem.
keith
Old 09-14-2003, 08:19 PM
Kind of a far fetched possibility, but I had a similar problem on my 86. Car would run fine, then lurch a bit, then run fine again. Turned out to be a broken wire on the engine harness side of one of the plugs for the flywheel senders.
Also, have you looked at your distributor rotor?
Tim
Old 09-14-2003, 08:33 PM
Tough to figure out without more data. Do you have access to any electrical test equipment? A scope trace of fuel and spark when it occurrs would be helpful.
But, to throw another known problem out there, the DMEs have been known to have solder crack problems due to flexing of the circuit board. Sounds like you've replaced about everything else.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 09-14-2003, 08:39 PM
