RMK RMK is offline
No Brake Lights!
My '80 SC brake lights do not illuminate. I've done the obvious, and checked the bulbs. They're fine. Any ideas?
Old 09-11-2003, 02:25 PM
scottb's Avatar
On my 84, there are two pressure switches on the master cylinder. When both go "belly-up," you lose the brake lights. If your car has the same set-up, that's almost certainly the problem. It's a easy fix, and Pelican sells the parts.
1984 Targa
Old 09-11-2003, 02:27 PM
What Scott says.
Old 09-11-2003, 02:28 PM
Chuck Moreland's Avatar
Check the fuse.
The 80 may have the mechanical microswitch at the pedal, not sure. Check that too.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-11-2003, 03:00 PM
scottb's Avatar
I had the same thought regarding the microswitch, Chuck. That's why I made reference to the "same set-up" as on my 84. If it's a microswitch, I think it's located in the cluster behind the floorboard. As I recall, they're adjustable.
1984 Targa
Old 09-11-2003, 03:11 PM
