Randy Webb's Avatar
964 distributor maintenance
What maintenance does a twin rotor distributo need? How often do you change that little rubber belt? And do you put some oil on the inside of the shaft? What else?
Old 09-12-2003, 07:05 PM
Send a message via AIM to 69 911s
Do you have th eupdate kit installed? If not, that is the main thing to replace so that the generated ozone from the spark doesn't hasten the natural deterioration of the rubber belt.
Cheers, Holder
when you see hoof prints, dont automatically assume zebras
Old 09-12-2003, 07:26 PM
