Pragmatic Dreamer
larry47us's Avatar
Short Shifter?
The shop that is restoring my 73 "E" told me that the tranny has a "short shift" kit on it, but he could take it out. Since I had never even heard about a Short Shift Kit, can you guys give me some opinions as to whether I should leave it in, or take it out?
thanks
larry
2004 - 911 - 996 Targa - Dark Teal Metallic, with Natural Brown Leather interior.
1973 - Viper Green 911E Targa - Kermit - gone but not forgotten
Kermit's Short Story and Pix 911E Website
Early 911S Registry Member #537
Old 09-11-2003, 08:08 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I cant think of any reason to take it out. I can think of plenty to leave it in.
Marc
Old 09-11-2003, 08:31 PM
drag racing the short bus
dd74's Avatar
I've heard from various sources that short shifters are hard on the synchros. I've never seen this for certain, but I'd just assume not have one. After I replaced the bushings on my linkage, the transmission's been as smooth as a baby's...
The Terror of Tiny Town
Old 09-11-2003, 08:32 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
I have heard that the kits are hard on syncros also but I don't buy it. I think that the drivers are hard on the syncros. I just installed the factory short shift kit in my SC and I would never go back. I have noticed a very small increase in effort, but that was all. The benefits far out weigh the extra shifting effort. If you shift a 915 the way it should be shifted (not like a drag car), it will last just as long with either shifter IMO. Others will disagree with me, but that is how I feel.
1981 SC ROW Coupe
Old 09-11-2003, 08:42 PM
UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
I love mine, wouldnt give it up.
Matt
'82 911SC Targa!
Old 09-11-2003, 09:43 PM
Carrera Sled's Avatar
Ditto CDiercks. I changed from OEM to a Weltmeister shifter, along with new shifter cup, linkage and coupling bushings. Much better, and now the shifter doesn't hit my leg or the seat when going into 2nd. I agree that synchro wear is determined by the operator, not the shift mechanism. I speed-shifted into 2nd once, 'cause I didn't want some ricer punk taking me (maybe something to do with the '96 Z/28 6-speed I also had at the time - it thrived on that abuse, and it never lost to ricers). I promised the Porsche I would never do that again .
I'd keep the short shifter, and just granny-shift it.
'85 Carrera Coupe, White Gold Metallic - 8" rear Fuchs, Fittipaldi steering wheel, Weltmeister short shift, Turbo tie rods.
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower." - Mark Donohue
Old 09-11-2003, 09:46 PM
The Weltmeister shift lever has a slight "leverage" advantage over the factory short shift lever. This results in slightly shorter throws for the WM at the expense of higher shifting effort. Some like it, some don't.
I have the FSS in my car and it's fine. Here's a pic showing, from top to bottom: factory, FSS and WM short shift levers.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 09-11-2003, 09:51 PM
