Making Carpets
Has anyone made their own carpets and can it be done affordably? I'm just building a daily driver and the cost of the kits would be better served on a different part of my car.
Old 09-12-2003, 02:49 PM
Raynald's Avatar
i do it !, i bought nice black carpet and used my old one for model and my wife sew a trim all around and i save a lot of US money and time for waiting for it ... and i am sure it fit better than my old one ....
Ray
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 09-12-2003, 02:59 PM
I was thinking of trying to cut it in, in 2 sections glued, since I don't have any templates.
Old 09-12-2003, 03:02 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
You can get the far less expensive rs carpeting. It's feltish, gray for a few hundred bucks.
I've done carpeting just by putting in a kit and that is hard enough believe me. Not like cabriolet replacement hard, but certainly lots of work in the garage with a staple gun. It just happens to be harder than you think it will be. It's not that you won't get it in there. You will, but it's not going to be good as you'd expect, I think....and if it's bad enough, a friend might put a "I (heart) Guadalahara!" bumper sticker on it.
-kb-
Old 09-12-2003, 04:07 PM
Hey I just learned how to spell Guadalahara.
Old 09-12-2003, 04:21 PM
Cheapest RS lightweight carpet set is less than $300.
Caliber
1987 911 Cabriolet
Old 09-12-2003, 05:41 PM
Trust Me's Avatar
I made my own carpet for a 914 I once owned. Turned out very well. Got some carpet from Home Depot and cut it out useing the old carpet as a pattern. Oh, I did not use any 1970's shag carpet either.
Troy
72' 911 T
97' Boxster
81' SC coupe / sold
76' slant nose
81' SC Targa / sold
77' s / sold
67' 912 / sold
89' 944 / sold
74' 914 / sold
71' 914 / sold
Old 09-12-2003, 07:51 PM
Certified Pre-Owned
BGCarrera32's Avatar
I just picked up an RS carpet set in domestic black needle punch, with a special order binding, extra binding and and extra yard of carpet. You get floor mats, kick panel pieces, rear skirts to replace the vinyl next to the back seats, RS rear deck piece, etc. Under $300 shipped from Bob at www.appbiz.com. Very nice stuff for the money. He advertises in the back of Excellence magazine. You can obviously make your own and go cheaper, but you need a decent sewing machine for going through the carpet and binding, and you'll burn some time doing it. Just beware...
-BG
'84 Carrera Coupe
Old 09-12-2003, 10:01 PM
47silver's Avatar
the po made the carpet in our car, looks like crap. i think carpet making is not an easy task as you need a heavy duty sewing machine etc. our carpte bunches and does not lay nicely at all ,
we have new from pelican and will post picts after we install i would think you would be better off to get a used set that is in pretty good shape.
1975 911S Targa
Silver Anniversary Edition
Old 09-14-2003, 07:57 PM
Trust Me's Avatar
I used 3m spray glue. It worked very well.
Troy
72' 911 T
97' Boxster
81' SC coupe / sold
76' slant nose
81' SC Targa / sold
77' s / sold
67' 912 / sold
89' 944 / sold
74' 914 / sold
71' 914 / sold
Old 09-14-2003, 08:04 PM
Mark Wilson
Guest
Posts: n/a
Sorry, but no you didn't.
Old 09-14-2003, 09:37 PM
Dang.
Old 09-15-2003, 05:17 AM
slater's Avatar
I just finished making my carpet and gluing it down. Took me the enitre weekend and cost me about $35 in carpet and $7 in glue. I didn't have any patterns, so i made my own with some paper.
Everyone that I told I was doing my own said "good luck with that!" but it honestly turned out great. (I wish i had a digital camera to show you) I think the name of the capert i used was flex form.. anyway, is stretches a little bit so that you can form it around and into corners as you glue it down. It is just plain dark black, but it made things so much easier. The only thing I didn't do was sew trim around the outside of the peices, but when I glued it down tightly you can't really see the edges unless you pay close attention.
I am really happy with the way it turned out and nobody has been able to tell the difference. It can be done if you have some patience! Just a couple tips about the glue- Make sure you use a glue that is okay for high temps ( i used 3M Super 76) because it can get hot in a car in the sun, and some glues will get sticky again if they get too hot. Also, if you use the flex form carpet, you HAVE to glue it down. If you let it just sit in there, it can get distorted or stretched when you step on it.
Anyway, if you go for it, good luck and post some pictures!
-kris out
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 09-15-2003, 09:34 AM
slater's Avatar
Guadalajara
Old 09-15-2003, 09:37 AM
Chuck Moreland's Avatar
-BG
I just installed this same needlepunch RS kit in my '73. It is very good quality.
The lightweight needlepunch is not durable as Sliverknit, but is much more so than the felt with very little weight penalty.
Unless you have experience doing this type work and a good carpet to use as a template, you will not get a result as nice as the appbiz kit. At under $300, it would be hard to justify making your own unless you are doing it for fun.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-15-2003, 09:38 AM
slater's Avatar
Well, for under $50, it WAS kinda fun, and it looks great. maybe i was lucky it turned out the way it did, but i still think with a lot of patience it can be done and look great.
Old 09-15-2003, 10:10 AM
Harlan Chinn's Avatar
Try Quetzalcoatl...If you need heavy duty sewing done, buy the materials, cut the pattern and take your carpets to tailoring shop (asian) with a heavy duty machine.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 09-15-2003, 10:11 AM
Certified Pre-Owned
...and that folks was my rationale.
'84 Carrera Coupe
$750 with German material (exact match) and labor. Are you sure you want to make the carpet yourself? Even buying the carpet set to install yourself is not a easy job. It's not just buy it and put it in. There is a lot of gluing and stapling involved.
Caliber
1987 911 Cabriolet
Old 09-15-2003, 11:26 AM
What year car are are you wanting to make one for? I've got a new set that I know fits '68 years, and probably others that I'm trying to get rid of...
1968 911L
2004 Dodge Dakota SLT Plus
Old 09-15-2003, 11:36 AM
