Jbabic's Avatar
2.7 crank
How does one tell if the bearings on a crank are standard. .25, .50, etc. part number on the bearing is 901 131 00. where can I check this bearing number at to see if my crank is standard or not.
Old 09-15-2003, 06:01 PM
pomaro's Avatar
hi,
it may sound a little bit silly, but if you are not shure, that there's no rebuilt on the engine:
measure! measure the bearings in the crank, measure your crankshaft.
my engine (3.0), although well rebuilt and running, got four different sizes.
unfortunately i can't tell you, wether there are differences in the spare part numbers...
greets
pomaro
je oller, je doller!
Old 09-16-2003, 02:29 PM
