Formerly bb80sc
Factors which affect torsion bar size decision?
Hello all,
I currently have 22/28mm t-bars in my SC and have considered larger in the rear. The car feels pretty balanced, but I wonder if certain factors determine whether or not I *need* larger t-bars. I have 9" Fuchs, LSD, and Bilstein Sports. Does having one or more of these lessen the *need* for larger t-bars? I ask this especially as to how it all relates to under/over steer. Thanks! -B
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
It all depends on what the driver is complaining about.
* Is the car bottoming? * Does it have a chronic push or is it chronically loose? This question should be followed by the question: when? Entry/middle/exit of corner? Highspeed? Low Speed? When on the gas/brake/balanced throttle? * Are the tires rubbing the fendors? When? * What is your tire wear like? Tire temperatures? * Where do you drive the car? Race? DE's? Solo? Street? As far as I know there are no absolutes, only different ways to fix problems. I'm of the opinion that "if it aint broke -- don't fix it".
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
If the car is balanced to your liking during high-speed turns with this 22/28 set-up, then I wouldn't change it. If the car still exhibits a tendency to understeer or just doesn't feel neutral enough (again - high speed turns), then you might consider 29s. There are things you can do before going to 29s, though. Sway bars (change in size or adjustment) is one example.
Every car is different and every driver has different comfort levels when it comes to a car that tends towards neutrality/oversteer, so this is a tricky question. I stress "high speed turns" because it has been my experience that even with the car relatively stiff in the rear, it will still tend towards understeer in low speed turns. High speed turns (turn 12 at Road Atlanta comes to mind) is a situation where you will see the car transition from understeer to oversteer. You don't want to exceed your "oversteer comfort level" in that turn. FWIW, my '76 has 22/29s and it feels great. To me. That was with the stock 2.7. The 3.2 in there now may make a difference. HTH, Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
In thinking about your question: "What factors affect T-Bar size decision" a little more, I don't think that I respond well.
What determines spring choice? * Car Weight and weight distribution * Suspension geometry * Center of gravity height at either end of the car. * Suspension frequency * Expected corning loads (in G's) * Tire and wheel size * Roll bar selection In Mark Donohue's book he alludes to doing some calculations and changing the springing on some of their cars. You can make up a spreadsheet to do the calculations. I tried it once and put in the data for my 911 as well as a couple of popular configurations and was surprised to see that the results came out as expected, with the cornering forces on each corner roughly proportional to the tire size. So in a nutshell, this is what Porsche did when they selected the T-Bar sizes.
Formerly bb80sc
Thanks guys! I plan to drive the heck out of her at Willow with the current setup and I'll go from there. I am mainly trying to figure out if I was optimal based on those other factors. I recently installed Poly Graphite camber plate bushings and this really seemed to help with understeer since it must hold the camber better. BTW, how much does the *driver* account for in these calculations
Senior Member
Here's a question: If you were to move from a seven/225 Fuch to a nine/245 how much would you increase the t bar if the current size is 24.1 and you want to keep the same ride characteristics? Would you go to 26 or so?
The front would go from say a 19 to a 21, and from six/205 to seven/205. The nature of this question is to relate tbar to tire size. This might be a bit too simplistic on my part... John
'78 Targa in Minerva Blue |
Great information here
I am going to install 23/31s in my street/track car in the next few weeks and I will report back. Probably way to stiff (I will be careful) and I may need to back off. I got a great deal on this set up used so I couldnt refuse. BTW mine is a 73 lite weight with a stock 3.0 in the back. Cant wait to feel the difference.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
I don't think that tires size matters in figuring spring rate except if your trying to acheive maximum cornering which is another subject. Selecting springs rates and torsion bars and properly tuning and setting them up is really for the purpose of maximising the tires contact patch with the road and therefore better handling/grip. Changing rear tire size as you speak of would be the type of situation (in my opinion) where you keep you setup and give a slight adjustment to rear torsion bar (assuming you have an adjustable one). I believe that changing engines and transmissions would effect the rear springrate more because of a change in rear weight (and overall weight for that matter).
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
The assumption within the question about changing the springs is that the current springs are somehow not fulfilling their desired function of supporting the weight of the car. I continued that assumption in my answer and assumed that the springs were in some way limiting the performance potential of the car. Quote:
If it was just a question of making sure that the tires are all perpendicular with the road, car designers would dispense with sprung suspensions and design the car with a rigid suspension like a kart. And beam axles would be all the rage at both ends of the car like on a Model T.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman Last edited by jluetjen; 09-17-2003 at 10:38 AM.. |
Formerly bb80sc
BTW, I need to make a plug for the modification I made to my Bilstein's. I cut down the rubber bump stops and it made a lot of difference with the suspension *unspringing* when compressed. I'd recommend this change. Details can be found at the Smart Racing website.
-B
Stickier tires impart more lateral loads which cause more roll which necessitates more roll stiffness. Sort of an oversimplification, but increasing torsion bar size has many benefits. Mike
Sure Mike, but now your back to the limit of adhesion idea. If you put stickier tires on, you'll be pulling more G's and your car will be leaning more which may (note that I didn't say will) put the car into a funny geometry zone or up against the bump stops.
I guess I'm just saying that we're in violent agreement.
Mike
Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
