clnilsen's Avatar
Sump Plate Question
Looking at this Pelican Parts Item, I see it included Studs. On a 1980 SC 3.0 engine, do I need to replace the studs in order to use this sump plate, or are the studs long enough from the factory to use this.
Anyone done this?
Thanks!
Chuck
1980 911 SC Targa *Sold!*
2003 Boxster
2013 Beetle Turbo cab
Old 09-17-2003, 01:06 PM
nigel911's Avatar
Sure someone must know...
I bought the kit to replace the slightly dented OE one on my 72, haven't fitted it yet though. Came with studs same as Chuck's.
Beautifully made bit of kit.
Old 09-17-2003, 02:05 PM
Early_S_Man's Avatar
Porsche Crest
Yes, the studs do need to be replaced with the ones supplied in the kit ... as the aluminum plate is around 3 times as thick as the OEM steel plate, and there probably wouldn't be enough stud threads left on the original studs for the Nyloc nuts to grab to.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 09-17-2003, 02:27 PM
hugo454's Avatar
yup, ya gotta change the studs.
Mine came right out.
Old 09-17-2003, 04:15 PM
