Im ready to invest into a front brake cooling kit. Is there a hands down supiror kit? Any advice or pics would be great.
Thanks R
Past: 04 Anniversary 911 #0895, 82 911 SC, 88 Signature Series Carrera, 88 911 Turbo Cab, 73 911T, 63 356B, 06 Cayenne |
OG's kit is fiberglass with 3" hose fittings, AJUSA's is aluminum with 2.5" hose fittings. I think they're comparable in price as well as performance. I've had both and they do the same thing. Take your pick.
Where you get the air from is debatable. Some folks use the A-arm scoops (as I did for a while). They work okay, especially if you want to keep the car stock looking. If you don't mind taking the foglights out, you can mount ducts at each of those locations and get even more air. I went with this method, using both the stock valence, a custom made one (from stock parts), and now a Ruf style f/g unit. I also made some A-arm manifolds (a la Smart Racing) to keep the hose from getting torn up from tire rub. Do a thread search and you'll find a lot of info. Hose Manifold Thread More
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS Last edited by GeorgeM; 09-17-2003 at 12:28 PM.. |
Thanks George,
i had done a search but, didn't find what i was looking for. My application is for racing only...
That paint is waaaay too pretty to be on a track! :>)
FWIW, I have the OG kit ducted to the holes in the front of my IROC front bumper. Seems to work fine. I was a little suspect of the fiberglass pieces, but it has held up fine over the years. Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
