How To: Identify 2.7RS MFI pump
Morning kids,
I'm looking at a MFI set up for the new race motor (this thing is eating $$$'s like you wouldn't believe - 7R case, 10.5:1 pistons, twin plug heads....)
How do I tell if the MFI pump is 2.7RS or 2.4E? - can you tell from the serial no. on the pump?? (It is very close to the no. on the pump of a real RS I have compared it to that I know has its original pump)
Is there something you can measure - stroke of the cam??
The rest of the setup appears to be ridgy-didge 2.7RS - 36 to 38mm throttle bodies etc
Any help greatlly appreciated
Cheers - Ryan
Old 09-18-2003, 05:17 PM
Warren Hall Student
Bobboloo's Avatar
The first seven numbers are always 0408 126 followed by three more numbers which give you the type of pump as follows
69' E 002
69' E 006
69' S 001
69' S 005
70/71' E 010
70/71' S 009
72/73' T 015
72/73' E 014
72/73' S 013
72/73' S 021
These are the Bosch numbers that are written on the pump. I don't have the number for the RS pump. I got these out of the check,measure adjust manual.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 09-18-2003, 07:18 PM
Thanks for that, the no. on the pump is 0408 126 015 (ie. 72/73 T)
How do you check if the space cam is 2.7RS or not??
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 09-18-2003, 07:24 PM
The number on an RS pump is 0408 126 019. Not sure about the the space cam, I have never seen mine apart.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 09-18-2003, 08:18 PM
This guy could probably tell you if there was a way to ID the cam without taking the pump apart:
Pacific Fuel Injection (Gus Pfister)
Suite B, 153 Utah Av
South San Francisco, CA
Tel. 650-588 8880
I think you should probably assume you have a T cam in your T pump. The RS cam is available if you decide to rebuild your pump to RS specs. I think the S and RS pumps have the same specs but maybe Warren Hall or someone else can clear this up...
Scott
Old 09-18-2003, 08:37 PM
other stuff on the pump???
PED 6KL60/120 R3Y 0408 126 015
Cheers, Ryan
Old 09-18-2003, 10:57 PM
Halm's Avatar
I believe Otto (http://www.ottosvenice.com/) has a real RS pump available for sale and I bet he would "deal" on it.
'17 Cayenne
Old 09-19-2003, 04:58 AM
