drag racing the short bus
Do 98mm pistons and cylinders require a 3.3 crank?
I read a comment on another thread that said 98mm pistons & cylinders will not work with the smaller-sized 3.0L Turbo crank. One must instead use these with the 3.3 crank.
Is this true? I always believed the 98mm pistons and cylinders were a direct "bolt-in." I never heard of a need for a 3.3 crank for this modification. Enlighten me, please...
The Terror of Tiny Town |
SCWDP- Shock and Awe Dept
According to Wayne’s rebuild book the 98mm pistons work great w/ the 3.0 SC crank for a short stroke 3.2. It’s listed in the favorite engine combo chart.
He does list a 3.2 case in there but he told me once that he could order the 98mm P&Cs that will bolt on to the 3.0 w/ CIS. Or you can get the 98mm RSR P&Cs and carb it if you really want to go nuts.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Hey Ryan: that's what I knew to be the case; that the 98mm p/cs work in accordance with a stock crank, and that to punch a 3.0 to a 3.4, one needs the 3.2 crank.
But with a 3.3 turbo crank in a 3.0 and 98mm pistons and cylinders, would that'd equate a 3.5?
Not sure. TRE just built a 3.5 for a customer. I forget what they used but I think it was a 930 (3.0 SC) case. They had to uses head spacers for the long stoke as I think you would have to do w/ the 3.3 crank but I really don’t know that much about the other cranks especially turbo (disclaimer saying that I don’t know what I’m talking about).
You have a 3.0 right? If I wasn’t doing the 3.6 thing and I didn’t have to worry about smog I would love to do the short stroke 3.2 w/ carbs. Fun Fun Fun!
You might have to do more research. I seem to remember reading that the early turbos were based on a 3.0 Carrera case. The 98mm P&C for an SC might be different. There are also 98mm P&C to fit a Carrera (3.2) crank (different wrist pin).
98mm P&C with a 74.4mm crank is a 3.4 not a 3.5 (which requires 100mm P&C).
1975 911S (in bits) 1969 911T (goes, but need fettling) 1973 BMW 2002tii (in bits, now with turbo) |
How many mm is the 3.3 crank?
According to the tech info on this site, 74.4mm with 97mm P&C.
Fun with maths: 74.4 * ((97/2)^2 * pi) = 0.550 litres - you need to divide by 1,000,000 6 * 0.550 = 3.300 litres (actually, it is 3,299cc if you don't round it). 70.4 x 98mm = 3184cc 74.4 x 95mm = 3164cc 74.4 x 100mm = 3506cc Easy.
98 mm pistons with 3.0 crank = 3.2
98 mm pistons with 3.2/3.3 crank = 3.4 100mm pistons with 3.2/3.3 crank = 3.5 That was my understanding of the combinations. Rick '78 930 |
And 98 mm with a 3.6 crank (which is what I have in my 930) is 3.45 liters....
Closest you can get to a 3.5 in a 3.3 case without boring the spigots. Gotta chamfer the heads just a bit to fit the longer stroke. |
Hi
I built up a neat motor a few years back .. 66mm stroke with 98 mm 3.3 turbo clys and had some J+E pistons made up total displacement was just short of 3 liters like 2.95 liters or something like that engine specs .. 911 carrera 3.0 case ( the ONLY 911 case that will allow early 66mm crank and 98 mm cly spacing ) 2.2 s crank 906 titanium rods ( same dimen. as a 2 liter rod ) 98 mm 3.3 turbo cly 98 mm custom pistons from J+E 3.3 turbo heads 906 cam grind very quick reving engine !..not much low end, but a screamer ! - Joe - |
Author of "101 Projects"
Hi all. Unfortunately, there's lots of mis-information in this thread:
- 1976-77 911 Turbo and European Carrera cases are the same (nearly identical). They have the smaller flywheel end (used from 1965) and the larger cylinder head stud spacing of the 3.0/3.2/3.3 cylinders from the later cars. - The 2.7 crank and rods and the 3.0 crank crank and rods are identical in stroke. Using a 2.7 crank and rods in a Euro Carrera or early Turbo case will be nearly the same bottom end as as a 911SC engine. - All the 3.0/3.2 CYLINDERS are the same (95mm). The 3.3 uses different cylinders (97mm, shaped differently on the exhaust fins). - The 3.2 pistons and 3.0 pistons have the same outer bore (95mm), but do not have the same piston pin offset. As a result, you cannot use 3.2 pistons with a 3.0 crank, nor can you use 3.0 pistons with a 3.2 crank. It just won't work. The 3.2 pistons that I refer to in the Engine Book's table is a special set of pistons and cylinders that are larger bore (98mm) and specifically designed to work with the 3.0 crank ($3600 new). There is also the same set that can be used with the 3.2 to make it a 3.4. These are also 98mm, but can only be used with a 3.2 crank. - The 3.3 and 3.2 crank are identical and can be interchanged. - 3.0 rods must be used with 3.0 cranks. 3.2/3.3 rods must be used with 3.2/3.3 cranks. They are not interchangeable. - If you swap your 911SC 3.0 crank and rods with ones from a 3.2, you must then switch to the 3.2 pistons and cylinders as well. At this point, you can buy the 98mm pistons and cylinders and upgrade from 3.0 -> 3.4. - A stock 3.2 is considered a long-stroke 3.2. It is the same engine as the 911SC, but with a longer stroke (different crank,rods and pistons). The short-stroke 3.2 is a 3.0 engine (3.0 rods, crank) with a big bore kit on it (98mm). I'm building the following engine: - 911 Euro Carrera 3.0 Case - 2.7 Crank and rods - 3.2 pistons and cylinders with the offset for the 3.0 crank - Turbo heads ported to 35/36 - Webers - HPX Twin-plug Ignition - Mod 'S' Cams Displacement: 3.2, HP: est 270? Compression 10.5:1. Hope this info helps! -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
It helps...but now I've forgotten my own question...
