-   -   What can I use to protect against rust? (http://forums.pelicanparts.com/porsche-911-technical-forum/127943-what-can-i-use-protect-against-rust.html)
EdT82SC 09-17-2003 08:56 PM
I've taken out my pedal cluster, and replaced all the bushings. While cleaning up all the crud under where the pedal cluster goes the floor felt kinda spongy. Inspecting it a bit further I could tell the coating on the floor there had cracked, and a small area of about 2" square was bubbled up. So I grabbed a screwdriver, and poked a bigger hole, and peeled back the bubbled up part, and found bare, shiny metal.
No rust! Woo Hoo!
http://www.pelicanparts.com/support/smileys/wat6.gif
So what can I use to re-seal this part of the floor to protect it from water, brake fluid, etc. that might find it's way down there in the future?
Thanks,
Neilk 09-17-2003 09:32 PM
Couple of thick layers of Por-15?
