-   -   Shell Rotella... Good? (http://forums.pelicanparts.com/porsche-911-technical-forum/127989-shell-rotella-good.html)
SprintStar 09-18-2003 10:14 AM
Hello All,
Just found some Shell Rotella in my local Shell store. I've read a long time back that Rotella oil is good for 911s... True?
Should I pour it in my baby? She's a 1967 911S. The oil is a straightweight 40 and I live in the tropics.
Currently I have got Caltex Havoline Synthetic in her.
Sprint.
jmohn 09-18-2003 11:04 AM
I use Rotella T 15-40 in my '78 SC. I don't know which weight you should use in your '67 (follow requirements in the manual). Shell Rotella is a high quality multi-purpose oil (meets both gas and diesel engine requirements) it should be fine for your car.
Jerry M
'78 SC
5axis 09-18-2003 01:02 PM
The search function found this gem..
http://forums.pelicanparts.com/showthread.php?s=&threadid=77815&highlight=rotella +and+specs
david 89 turbo cab
rotella cult member
Doug Zielke 09-18-2003 01:14 PM
I used it until recently switching to Kendall GT 20w-50.
Rotella T is good oil. Never used anything else in my boat's CAT 3208 diesels.
Sonic dB 09-18-2003 02:58 PM
I use Rotella T and love it. My car does not burn much oil at all....almost imperceptible amount....and the car never leaked before (it just "sweated" a tiny bit of oil on the oil line connections). Since switching to Rotella T, there is no more sweating. I just drove 400+ miles on it last night and temp barely rose up to the middle mark.
Rotella T is good for classic Porsches.
SprintStar 09-18-2003 06:04 PM
Ah... Here's my problem... The bottle I bought is NOT Rotella T. It just says Rotella. Yes, it's made by Shell but it's made in Singapore. How do I know it's the same as Rotella T?
From what I read about Rotella, it seems to be made for diesels and this is the same oil taxis here use...
So, can I use it on my 911?
I'll try read the API label later and post it.
Sprint.
